Re: farmall M charging problems
Posted by Jon Hagen on December 20, 2011 at 15:13:03 from (69.26.23.96):
In Reply to: farmall M charging problems posted by boxchevyman on December 20, 2011 at 11:30:11:
Check that the fan belt is tight enough to turn the water pump at full speed.
The water pump turns the generator / alternator,
I have run into several early IH "no charge" situations where the only trouble was a loose fan belt causing waterpump / fan to turn too slow for the generator / alternator to function.
