kenneth house , You are partly correct, A "1 wire" 10SI alternator can lose it's residual magnetism which prevents charging. You do NOT polarize the alternator, you "field flash" it by momentarily jumpering the #1 regulator terminal to battery voltage, usually from the #2 regulator sense wire or BAT stud on the alternator rear. I doubt that is the problem in this case, as the parts store testing the alternator should have flashed the field.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
