Re: Hydraulic Fluid in engine oil
Posted by CNKS on December 20, 2011 at 17:32:09 from (216.144.104.128):
In Reply to: Hydraulic Fluid in engine oil posted by dchall on December 20, 2011 at 16:01:51:
All you need is a SKF or National seal on the shaft of the pump, and a speedi sleeve if the shaft has a groove in it. It may only have an oring, but I don't think so. If that is all that is wrong you don't need any more parts.
