I know the MTAs have different tolerances inside them.(At least from what others have posted on here.)
You CANNOT run 90 wt in an MTA,400,450 !!!!
It would be the equivilent of putting 90 wt in an automatic trans!Smoke the T/A
HYTRAN is NO comparison to gearlube as an ACTUALL "clinging" gear lube.(like a 90 wt 140 weight grease.) You use HYTRAN because you HAVE to in certain situations.
The WHOLE reason for running HYTRAN (AKA; A variation of ATF) is to keep from destroying the planetarys.Those planets wont live in gear grease.You couldnt even shift them in 90 wt.(try that on a 40 deg or less day!) Also,in newer tractors,90 wt will not work as hydraulic fluid either.
The ONLY other factor is the LOW RPM of the final drive.If the rear axles were a "high speed" rear end like a car,they wouldnt make it.
Newer cars do use ATF in their transmissions,but the tolerances are different.
End of story:If it doesnt have a T/A,DO NOT use HYTRAN! Unless you live in ALASKA and the tractor usually runs in -20 weather all the time.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
