Posted by farmerjohninpa on December 20, 2011 at 18:25:10 from (68.32.24.184):
In Reply to: Drilling a shaft posted by clint s on December 19, 2011 at 18:32:15:
clint; if you go to a machine shop nearby, they will have what are called "drill bushings" these are hardened steel, that you can use to get the exact center,,,measure the o.d. of the spline shaft, this will be the first bushing you need ,the second one will fit inside the first bushing and should have a 1/4"hole in the socond one that being the starter hole in the shaft.the bushings should be 1-1/2" long for good stability...all these bushing are ground to exact dimensions so they will keep every thing aligned and kept on center. you should ream the last 20 or 30 thousanths so as to be a tight fit for your dowel pin to replace the stub snapped of. a machinist will know just what you need and the proper drills to do it,,, john
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
