Re: m vibration
Posted by AG in IN on December 20, 2011 at 18:29:26 from (67.236.107.41):
In Reply to: m vibration posted by rustyfarmall on December 19, 2011 at 17:30:08:
Mike1972chev said: (quoted from post at 02:36:12 12/21/11) Are you EVEN kidding about the "grinder action" here???
Left the broken starter nose in it?????
I guess ANYBODY works on these??? :(
Mike, I couldn't make this up if I wanted to. This Super M shook terribly. The broken nosecone took quite a bit of material off of the outside of the flywheel. There were alot of filings around the hole at the bottom of the clutch housing. Fella at the machine shop said that unless it was something rare to find another flywheel.
It's been 5 or 6 years since I fixed this. I believe it was the finger adjustment screws that were ground or filed down on the pressure plate. Either that, or the pump resovoir did it, but it sure looked like someone took some more material off to make it clear.
Belly pump resovoir for a Super M is different than an M for the larger clutch to clear. IH's last available replacement for all was the Super M one, but hasn't been available for years and it wasn't easy to find one that wasn't in a running tractor. Proper pressure plate was readily available aftermarket.
AG
This post was edited by AG in IN at 18:34:37 12/20/11.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
