I believe that an alternator rotor can hold residual magnetism I also believe that (if wired as a 3 wire system as described in Bob M diagrams, that it does not need the residual because it gets fresh new voltage to make NSNSNS around the rotor poles. One wire setups might take longer to self start if left for a long time. Solid state devices (as in your regulator) are at times strange in operation. There could also have been a connection that "flashing it" bridged. Even if I were standing there, it is ompossible to see the junctions and contacts being used. So the answer would be tha same either way. It is working, Use it. Thanks for asking. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
