All that would depend on the ground type, how deep and wheel slipage. SM from the differential back is mostly the same as a 450 farmall. Some ground here a 3 bottom is all a 450 wants at 8 inches. 560 parts after the serial break or early updated differential, differential carriers, bull and pinion gears and bearings will work in a SM. If you want it to look stock on the outside have the OD of the bull pinion retainers turned down to SM OD size. If you use one keyway axles from a 560 different wheels is needed. After a serial # break 560 came with the parts and no triangle was put on them. Some other improvements were added toward end of production. Also there was a serial break that the rear housings were changed. Main shaft rear bearing and retainer was change and wall of housing strengthened for retainer that mounted with 4 bolts instead of 3. Same as the 660 was using.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
