Re: Driver pin removal
Posted by Farmer Bob on September 04, 2000 at 08:58:58 from (208.49.9.251):
In Reply to: Driver pin removal posted by Bruce on September 04, 2000 at 07:07:50:
Bruce, Look on either side of the shaft where the crank pin is located for a set screw that's holding the pin in. It will be there under some grease and dirt so look close. It sits perpendicular to the pin kinda like this -:- Should have a slot for a screw driver for removal. Good luck..FB
Post A Followup
: Re: Re: Driver pin removal
