Posted by glennster on December 22, 2011 at 09:24:55 from (76.223.247.78):
In Reply to: HTA posted by Roy Prins on December 21, 2011 at 16:59:30:
if you want to use the h cover, its pretty easy to modify. the m+w live pump kits had instructions in there to do it. check fit your pump first to the cover. the bottom two bolts should line up correctly, the top two will be about 1/3 bolt diameter off center. remove the pump, run two bolts in the top holes, saw them off as flush as you can with the cover, then file them smooth. re-mount the pump, then go in with a drill bit that fits snug inside the pump mounting holes. drill just enough to mark the new centers of where the bolt will be. remove the pump, and drill new holes to accept the tap size. i think the bolts are 3/8 coarse thread. drill as deep as the old holes were, then tap the holes. the pump will now bolt right up. it is advisable to change the camshaft gear to the later style, it was a lot heavier gear. the early gear was thinner an had holes drilled in it. the old gear will fail with heavy hydraulic use.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
