Posted by CNKS on December 22, 2011 at 17:40:18 from (216.144.104.128):
In Reply to: Farmall H axle seal posted by Aaron Halfmann on December 22, 2011 at 17:27:09:
You can run SAE 90, 80W90, 85W140 or even straight 140. You can pull the bearing if you want to, but if you can't move the axle up and down with the wheel off, it is probably ok. When I did my Super H I took the axles and housings off and replaced the seals along with the gaskets between the rear case and the housing. I had the bearings out, and decided that they were ok. Currently doing the same thing to my Super M. I did replace the ones in my 460 high utility because I could move the axles.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
