Re: 706 bleeding the hyd. system
Posted by ihman73 on December 22, 2011 at 17:44:31 from (38.104.162.142):
In Reply to: 706 bleeding the hyd. system posted by terry mcthompson on December 22, 2011 at 15:31:39:
Just a guess but you probably don't have brakes & the TA won't shift either. If it is limited to the steering, bleed the lines on the steering cyl. Otherwise there is an o-ring that requires splitting the tractor between the speed transmission and the rear end on the suction tube. Before jumping to this change the hyd. filter and clean the suction screen for the mcv pump. See if the oil is foamy, which would indicate a suction line leak.
This post was edited by ihman73 at 17:45:03 12/22/11.
