Re: 706 bleeding the hyd. system
Posted by mkirsch on December 23, 2011 at 05:25:49 from (64.80.110.75):
In Reply to: 706 bleeding the hyd. system posted by terry mcthompson on December 22, 2011 at 15:31:39:
Take your air compressor's blow gun and a rag, and pressurize the rear end through the fill tube on the deck, and turn the steering wheel.
It could be as simple as the system losing prime. If it happens again you've got an air leak in there somewhere.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
