Re: Cub cyl. Head
Posted by Janicholson on December 23, 2011 at 10:36:50 from (96.24.99.126):
In Reply to: Cub cyl. Head posted by BenB on December 23, 2011 at 09:46:28:
If the head is like a QWERTY keyboard, the sequence would be Y-B-U-V-T-N-I-C continue that pattern to the ends. Start with 10 ft./#, then go to 25, then 50, on up to the correct torque. Run the engine to operating temp, then let cool and retorque. If the bolts seem to not want to tighten any farther than they were, I loosen each one (one at a time) till the wernch just turns the nut a tiny bit looser, then tighten. If they tighten at first, just do that. My process breaks the static friction and allows a trew torquing of each. Do not loosen them more than just a tiny turn of bolt, and only one at a time. Jim
