Re: Int harvester 4166 4 wd stuckin four(4) wheel steering
Posted by TedinNE on December 24, 2011 at 07:26:17 from (74.85.105.144):
In Reply to: Re: Int harvester 4166 4 wd stuckin four(4) wheel steering posted by Dewayne Brown on December 23, 2011 at 18:35:16:
As Dewayne said, check for the linkage rod for being bent.
Also under the right hand corner of the cab is a link arm with a pin through it. If the pin is sheared it will cause the rod to bend.I am not sure how you were supposed to replace the pin with a cab on. Was able to drill a hole trough the floor and drive in a new pin. If the pin is sheared It will continue to bend the kinkage. Learned this the hard way.
