Posted by ShaggyM on December 24, 2011 at 11:20:42 from (50.83.17.32):
In Reply to: Super C Carb posted by 53DC on December 24, 2011 at 10:16:33:
I have 3 carters taht run great! The worst part of them is the pot metal or Alumin (spelling) fuel bowl. It get warped and it needs to be squared up. There are 2 jets in the bowl that need to come out so you can sand it flat. one is raised and it usually comes out pretty easy the other is set down a little but if it doesn't come out you just have to spray carb cleaner thru it to make sure its clean. Soak the bowl in White Vinegar it helps with teh jets.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
