Re: IH 424 Diesel Glow Plug Problems
Posted by JimB2 on December 24, 2011 at 13:54:55 from (174.115.9.174):
In Reply to: IH 424 Diesel Glow Plug Problems posted by Zachary Hoyt on December 18, 2011 at 15:29:38:
Yes, the front glow plug looks broken, so none of them will be working.
The wiring looks correct as you can see starting from fuel tank side the black wire from dash glow plug indicator is on outside connector then copper wire goes next block then next copper wire on outside, next wire on block side and final wire from outside to ground bolt on block.
JimB
