Re: Farmall C 12-volt Conversion with Magneto
Posted by El Toro on December 24, 2011 at 14:15:13 from (108.3.225.57):
In Reply to: Farmall C 12-volt Conversion with Magneto posted by Keven McNeice on December 24, 2011 at 13:41:12:
Your alternator or generator is only used to charge your battery. Since you have a mag it doesn't require any battery voltage. Don't run any battery voltage to your mag. You still need your switch that ground's the mag when shutting down the engine. You need to look on some of the earlier posts by Bob M or John T for their wiring diagrams when wiring an alternator. You should see around 14 volts across the battery terminals with the engine at 1/2 throttle or better. Hal
