Re: Belt pulley 1948 Farmall H
Posted by Nebraska Kirk on December 24, 2011 at 20:46:27 from (207.91.4.159):
In Reply to: Belt pulley 1948 Farmall H posted by dcpky on December 24, 2011 at 19:34:06:
You don't need to remove the entire belt pulley gearbox to change the seal. Remove the bolts that are right behind where the pulley bolts to the flange, the shaft will then slide out. Remove the gear and bearings from the shaft and the you can slide the seal retainer off and change the seal.
