Re: farmall H 9 spd which brand is it?
Posted by farmallhal on December 25, 2011 at 12:08:10 from (71.49.65.127):
In Reply to: Re: farmall H 9 spd which brand is it? posted by jmducks1 on December 25, 2011 at 08:13:02:
After looking at your post relative to a "better road gear" 5th or the road gear on your H is not affected or enhanced with additional speed. Only gears 1, 2, 3, and 4 will be increased which will put them all in a speed range between the original 4th and 5th on your tractor.
Also, you should be aware that having the Heisler engaged in high range also affects your PTO and hydraulic belly pump if you have those features by speeding them up. Both my M and H have a hydraulic pump disconnect which needs to be activated so as not to over-speed the belly pump when using the high range gears.
