Re: farmall m steering gear removal
Posted by E V Ward on December 26, 2011 at 08:33:43 from (69.171.176.233):
In Reply to: farmall m steering gear removal posted by jim warehime on December 26, 2011 at 08:27:21:
Take the grill off, take the cover off, loosen the nut from the gear. When you turn the wheel the worm gear will pick up on the gear and you can lift it out. Sometimes you can ground the bottom of the gear so it will slide on more and it will fix the problem.
