Re: Serial no. plate
Posted by Wardner on December 26, 2011 at 23:02:47 from (4.154.238.1):
In Reply to: Serial no. plate posted by David Cooper on December 26, 2011 at 18:32:58:
I've never done it on an IH product but I assume you were sent spiral shank rivets. They are driven in like nails.
If your center section is not bolted to the engine, you drive them out from the inside. Otherwise, you will have to remove the head and drive them through from the outside. You may wind up with holes that are too big. Epoxy will fix that.
You could use a grinder but I would use a small chisel so you don't get grinding marks. Those will be the marks of an amateur.
