Re: Generator or alternator
Posted by gene bender on December 27, 2011 at 06:18:45 from (67.55.227.100):
In Reply to: Generator or alternator posted by BruceS. on December 27, 2011 at 05:40:01:
Those generators served for years andyears and they will still serve. Making the bracket rewiring and then change all the bulbs is fine if you can do it and make it work new brushes and clean the commuter with maybe new bearings and it will work again. Bottom line is how much is the tractor used does it need to start everyday in cold weather and the list goes on
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
