Re: Generator or alternator
Posted by rustyfarmall on December 27, 2011 at 07:01:02 from (216.248.71.224):
In Reply to: Generator or alternator posted by flopguns on December 27, 2011 at 05:40:01:
Really? My dad bought a Farmall H brand new in 1949. Sold that H 50 years later when he retired. I spent countless hours on that H and I don't remember EVER having any problems with the charging system other than MAYBE replacing a battery 2 or 3 times.
I now own 2 Hs that get used on a regular basis. One of those Hs needed a new generator belt when I bought it 14 years ago, and hasn't given a lick of a problem since then. The other H needed a cut-out relay because a previous owner let the smoke out of it. It has not given an ounce of trouble in the last 13 years.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
