Posted by rustyfarmall on December 27, 2011 at 08:20:18 from (216.248.71.224):
In Reply to: Generator or alternator posted by Crazy Red Power in SE-WI on December 27, 2011 at 05:40:01:
Personally, I have never experienced cold weather starting issues with a 6 volt system, so I see no need to do a 12 volt conversion, BUT, if any of my original 6 volt generators DO go belly up beyond a new set of brushes, a 12 volt conversion will be the least costly way to fix it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
