Re: Serial no. plate
Posted by Brian Schmidt on December 27, 2011 at 08:53:15 from (69.66.236.124):
In Reply to: Serial no. plate posted by David Cooper on December 26, 2011 at 18:32:58:
I have done this by drilling the center of the old brass rivets. This seems the quickest method. It is easy to get off to one side to much though. Care must be taken.
Others have suggested using several thin putty knives driven in behind the plate to pry the tag up. Then after you get several in there, you can pull them out and use side cutters to get under the head and pull the rivets out.
