Re: Something To Ponder On A Cold Winter Day
Posted by RedRoundhead on December 27, 2011 at 10:32:09 from (24.106.38.186):
In Reply to: Something To Ponder On A Cold Winter Day posted by 2+2 Guy on December 27, 2011 at 09:19:40:
I think of it like this.
On an automotive ECU, the ECU turns the "grounding" of any given circut on and off. Which turn the electron flow on and off. Which would pulse, say, a fuel injector. The voltage is always at the fuel injector; it just need a path to complete the circut, and fire the injector. So the ECU "grounds" it.
As was stated, less arcing, because you are switching less energy, post-load.
Not that what I said answers your question.
