Re: What's the Best Way to Pull Engine?
Posted by rustyfarmall on December 27, 2011 at 11:50:26 from (216.248.71.224):
In Reply to: What's the Best Way to Pull Engine? posted by Owen Aaland on December 27, 2011 at 11:33:09:
You're half way there already. Fasten a couple of chains to the engine block using the holes where the head studs were, hook the chains to your hoist, tighten the chains, then remove the frame rails, and then remove the engine.
