Posted by wayne in mn on December 27, 2011 at 15:01:54 from (24.179.165.214):
In Reply to: ballast resistor posted by kenneth house on December 27, 2011 at 14:35:56:
To "resist" the extra voltage to the points. Using the original 6 volt coil, the higher voltage will rapidly burn your points unless a resistor is inserted in the circuit between the switch and coil.
Use a 12 volt coil with a built-in resistor and you should have no troubles.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
