Posted by Janicholson on December 27, 2011 at 15:58:11 from (96.24.99.126):
In Reply to: knock posted by Nicksdad on December 27, 2011 at 15:07:16:
Wrist pins do make those disappearing noises. they also can run for tens of years with the same sound. If it gets worse, or starts knocking earlier, I would worry a bit. Sometimes carbon (or a screw from the carb) can be found being pinched between the head and the crown of the piston. When the rod heats up, it hits the head. when cold it is not touching. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
