noisy trans B-414
Posted by Fritz Maurer on December 27, 2011 at 17:47:52 from (216.137.136.168):
2ond gear high range howls as if it was running in reverse. It also the ideal gear for many chores. Is this a common fault of these tractors? It originally had a 1501 loader, both the tractor and the loader were beat to death. Is this something that is repairable, or do they all make this racket? If I can't get new gears, what tractor family is this unit similar to, so that I might increase my chances at the salvage yard? Thanks, Fritz
