Re: What's the Best Way to Pull Engine?
Posted by John - OH on December 27, 2011 at 19:28:10 from (71.48.77.162):
In Reply to: What's the Best Way to Pull Engine? posted by 400D Guy on December 27, 2011 at 11:33:09:
I think your on the right track. Chain the engine to the hoist, unbolt the side rails, then unbolt the engine from the rest of the tractor. Just a note that engine is one BIG HEAVY piece of iron. I did my SMD by myself but would recomend if possible to have a second set of hands to make things easier. Definitely have a plan as to what you are going to do with the engine once removed. Good luck and have fun.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
