Re: ballast resistor
Posted by old on December 27, 2011 at 21:38:57 from (209.86.226.57):
In Reply to: ballast resistor posted by kenneth house on December 27, 2011 at 14:35:56:
A ballast resister drops the voltage down to the level that the coil was made to work at so you get the faster spinning of the starter but at the same time limiting the voltage to the coils so as not to burn up the coil which in turn can/will cause the points not to last as long
