Re: farmall c heat sending unit
Posted by gene bender on December 28, 2011 at 03:11:35 from (67.55.227.100):
In Reply to: farmall c heat sending unit posted by mern on December 27, 2011 at 22:04:00:
First of all you dont have a 46C as they didnt make the C untill late 47. You say a combine engine so that leaves a couple of places. The top radiator outlet,the head front by a headbolt,the lower outlet going into the radiator, Thes are places where there should be a pipe plug and that is where you can put the sender. Getting a reading at the bottom area is the lowest temp in the engine as thats the way the thermo system works. Now you didnt say whether your engine has a water pump as many were added.
