Posted by Haas on December 28, 2011 at 12:23:25 from (75.201.68.178):
In Reply to: 424 gas posted by gutterman on December 27, 2011 at 19:49:09:
The live PTO was an option on the 424, but I think most had it. It is a two stage clutch. Push the clutch pedal down half way and the tractor stops, but PTO continues to run. Clutch all the way down stops both tractor and PTO. Power steering was also an option. The ones without power steering tend to be a bit worn and have steering play. The 424 also has a separate hydraulic system and reservoir that does not use the transmission as the reservoir. I used to own one of these and it was a tough old tractor. I got rid of it because it did not have power steering. I had some troubles with the fuel cut off solenoid on the carburetor and also problems with the lift. I had to replace the piston in the cylinder on the three point hitch lift. The original cylinder had a leather seal which wore out and then wore out the piston. Many Mahandra parts will work on the 424 and are cheaper than the parts from IH. The early Mahandras were almost complete copies of the IH 424 series. If the tractor is in good condition it should be a good buy at $2500
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
