Re: International 1586
Posted by scotc on December 29, 2011 at 04:28:18 from (72.100.99.3):
In Reply to: Re: International 1586 posted by larryanderson on December 28, 2011 at 22:19:09:
You're thinking of the 66 series cab.
The 786 we had had a lot of troubles with the range shifter shaft snap ring. We ended up putting a hatch in the side of the cab to be able to get it fixed so it wouldn't come apart again.
The 15s are a good tilage tractor. You WILL miss the 4th gear if you want to run a discbine with it. Second gear can be tricky to hit in the 66's, I don't know about the 86's.
