Re: TA To use or Not to use????
Posted by dhermesc on December 29, 2011 at 06:10:54 from (24.248.193.103):
In Reply to: TA To use or Not to use???? posted by craigreavley on December 29, 2011 at 05:36:48:
Our 886 had over 24,000 hours on it when it was sold. The TA (used regularly and properly) was only replace once. Never had another one go out on any of the larger tractors (with the 4+2 transmissions). Our 656 also has 20,000+ hours - the TA went out on it in 1981 after 13 years of use (and at least 12K hours). It was run for another 10 years without the TA and my brother replaced it during an overhaul in 1992. 19 more years on it without an issue.
My 1957 Farmall 350 has only a few thousand hours - the TA is fine. Admittedly it rarely gets used - usually in road gear pulling hay wagons.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
