Re: TA To use or Not to use????
Posted by John A. on December 29, 2011 at 06:35:34 from (76.1.122.180):
In Reply to: TA To use or Not to use???? posted by craigreavley on December 29, 2011 at 05:36:48:
craiggreavley, The subject of TA s is one of the most debated topics here on the Boards as any that occurs.
****School 1, Use it, Drive it, like you stole it! Keep the throttle wide open. Use the TA to Farm with in TA the same as you would in Direct! Instead of 4 speeds w/ a high/low this Theory say No I have 8 speeds.
****School 2, Use it, But only in the tight spots,.... ie run in Direct all the time then when the land get harder, and the engine loads back, Smartly snap the TA lever back into TA, get through the tight land, Shift back into Direct in one motion, With a ever so slight pause at the midway point. This was the method taught to me by MY Local Dealer, Whom I went to College with!
This theory says I have 4 speeds with a high/low trying to run in the High side (Direct) except in tight spots.
There is evidence that Both Schools work equally well. But the Issue seams to be more times than not is Keep The Clutch and "TA" Adjusted in Specifications ALL THE TIME!!!!!!!!!!
out of adjustments TA s seam to have a Death Sentence on them
I am sure I have left out some important details that other may have to fill in. Hope this helps!
Later,
John A.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
