Re: farmall 706 w/n fire
Posted by oldtanker on December 29, 2011 at 07:03:46 from (66.228.255.223):
In Reply to: farmall 706 w/n fire posted by scott cook on December 20, 2011 at 08:13:50:
Make sure you have fuel! Start with checking at the filters. Then at the pump and then at the injectors. Once you know you have fuel to the injectors and not fluid (water), fuel, make sure the return line isn't plugged. Went through this a couple of years ago on a guys AC 190. Tractor had been running and quit. So much condensation in the fuel tank that both sediment bowls were full of ice. After thawing it out got about 1/2 a gallon of water out of the tank.
Oh and fix the glow plugs!
Rick
