15/30's and 22/36's axles
Posted by greyfoxxca on December 29, 2011 at 08:50:40 from (137.186.181.248):
I have a 1925 15/30 that looks to be a good runner. Good compression when turned and no obvious faults.
It was converted to rubber and all tires are rotten and 3 are flat. I do not want to waste money on rubber as I want steel on it when finished. I have a number of 28 and newer tractors with steel. They all seem to have splines and not the key.
What year was the change made?
Has anyone changed the axles over to the splines shafts and roller bearing?
I am finding it very hard to find earlier than 1928 tractors. Does anyone else run into this problem?
Is the front axle a straight across swap?
thanks
George
