Re: TA To use or Not to use????
Posted by mkirsch on December 29, 2011 at 10:08:45 from (64.80.110.75):
In Reply to: TA To use or Not to use???? posted by craigreavley on December 29, 2011 at 05:36:48:
There is one simple rule for using the TA: NEVER pull the TA to slow down a load. Only use the TA if the load is slowing you down.
If you follow that rule, your TA last a long long time, provided it has not been abused in the past.
You always run the risk of the TA going out on you on the next pull, but you can't go through life worrying about things like that or you will never get anything done.
The engine could blow up the next time you run the tractor, and that's a whole lot more expensive to repair than a TA, yet you don't even think about starting that tractor up and going to work!!!
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
