Re: TA To use or Not to use????
Posted by pete 23 on December 29, 2011 at 10:29:02 from (74.32.238.142):
In Reply to: TA To use or Not to use???? posted by craigreavley on December 29, 2011 at 05:36:48:
I see no one mentioned that the TA wears a certain amount even if you do not use it as the over running clutch is always over running when in direct drive. On the mechanical TA the direct drive dry clutch is released every time you push in the clutch so the fingers etc are always subject to wear and on the hydraulic units the direct drive clutch is released every time you push in clutch. No way you can drive the tractor with out TA getting some use all be it that it is not severe use.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
