Re: 806 Engine
Posted by Larry B 1486 on December 30, 2011 at 14:31:59 from (98.19.160.144):
In Reply to: 806 Engine posted by OldfarmAl on December 30, 2011 at 08:58:31:
270-247-2219, Smith repair in Mayfield, KY. Steve Smith runs a large tire and tractor repair shop. He sells new, used and aftermarket IH tractor parts and has a IH tractor salvage yard. He ships nation wide. I bought a complete DT 361, radiator, hood, air cleaner, everything needed from a 1206 and put it in my 856 from him. He gurantees them. A 361 or 407 will work in a 806. The 407 is the same motor just different bore and stroke.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
