Re: Any info on these Farmall M? cultivators?
Posted by Jim Becker on December 31, 2011 at 08:24:15 from (71.252.156.130):
In Reply to: Any info on these Farmall M? cultivators? posted by GaCub on December 31, 2011 at 08:01:11:
So many variations of culitvators it is hard to tell, but it looks about right for an HM-250. The fertilizer unit might be HM-53C, which was used with the 250 cultivator. If you have Guy Fay's data book, pull it out and look at the front cover. If you don't have it, look at it on Amazon.com.
http://www.amazon.com/International-Harvester-Tractor-Data-Book/dp/0760303215/ref=pd_rhf_se_p_t_2
If you decide there is too much missing or it isn't good enough to ever use again, I've been looking for the cylinder mounting brackets that bolt to the tractor frame rails.
