Re: Cub crankshaft seals. Front or rear first?
Posted by K-Mo on December 31, 2011 at 08:31:32 from (67.55.164.5):
In Reply to: Cub crankshaft seals. Front or rear first? posted by moondoggie on December 30, 2011 at 19:48:21:
When installing the front seal make sure it is centered with the crankshaft. If not you may need to remove the front cover to reposition it.
During engine assembly, the crank pulley should be installed before bolting the front cover down. This allows the front cover to locate itself in reference to the crankshaft.
I have experienced instances when this procedure had not been followed. The pulley would catch the seal lip and fold it inward instead of sliding into the seal.
