Posted by CNKS on December 31, 2011 at 08:50:04 from (216.144.104.128):
In Reply to: No power to starter posted by Tom300u on December 31, 2011 at 08:43:05:
I don't remember of the 300 has a push button or just works off the key. If so it could be bad. Remove and clean ALL the connections. The battery cables often get corrosion under the insulation that is not visible. The problem is probably in one of those two places, I doubt if it is the starter. Be sure the battery will hold a full charge, if not replace it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
