Re: No power to starter
Posted by JRSutton on December 31, 2011 at 09:02:32 from (75.130.109.233):
In Reply to: No power to starter posted by Tom300u on December 31, 2011 at 08:43:05:
Not a fix to your problem - but just want to point out that voltage is no indicator of current carrying capability.
The fact that you see 6 VOLTS at the solenoid only means you have a connection to the battery - it does NOT mean that connection can support all the current that's required to turn the starter.
Voltage means very little (You could stack 4 brand new AA batteries in series and get six volts, but they'd never provide enough current to turn the starter)
Somewhere in your circuit, there's resistance that's keeping the full amount of current (power) from reaching your starter.
If you've cleaned all the connections WELL - including ground connections - I'd try a jumper cable directly from the battery in the tractor to the starter to see if that works.
If not - it means your battery is the problem.
If it does - work back from there using the jumper cables where you can to do a direct link to the next connection in the circuit.
Try to isolate the bad connection.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
