Posted by D Slater on December 31, 2011 at 09:28:27 from (184.15.0.43):
In Reply to: No power to starter posted by Tom300u on December 31, 2011 at 08:43:05:
When you turn the key to start does it stay 6 volts at the solenoid engaging terminal? If so is the charger set higher than 6 volts and more amps? If starter solenoid works starter by jumpimg from battery wire post to the small terminal, problem just about has to be power to switch, switch, switch to small post or solenoid bad ground even though some of those parts were replaced. Not sure if some 12 volt selenoids if used with 6 volt would act like that or not, thats why I asked the voltage and amps of the charger.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
