Re: Red light next to the key on a 966
Posted by pete 23 on December 31, 2011 at 10:54:31 from (74.32.238.142):
In Reply to: Re: Red light next to the key on a 966 posted by craigreavley on December 30, 2011 at 15:51:29:
It goes to the red lamp. It is the grounding wire for the lamp to turn lamp on and the sending unit is nothing more or less than an on off switch which is closed to ground when less than 4 psi and opens with pressure above that to turn lamp off. You will also notice, the dump valve is hooked to the clutch pedal and dumps ta pressure when ever you press clutch in and this in turn dumps all lube pressure so light should come on with clutch depressed. If your lamp is on and the wire is cut, that wire is grounded between that point and the lamp.
