The only reason a feeler gauge would get "damaged" is if the rocker arm surface and the valve stem end were "cupped" due to lots of wear. IF your rocker arm and valve mating surfaces are re-ground to original condition, you can indeed adjust the clearance while running. I have done this many times over the 50+ years of rebuilding engines. There are many ways to rotate an engine while setting the valves; use the suggestions of the others who have written in this post.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
